LT1/LT4 Tech 1993-1997
when do you run outa gas
Old May 11, 2012 | 08:51 PM
  #21
llll1lll1's Avatar
I've run down to about 1/8 tank and was scared that it would start sucking air in the pump.
However, when I filled up, it was only 14.5 gallons. How many gallons does the tank hold? I thought it was about 17.
(I usually fill up at 1/2, which is 11 gallons)
Old May 11, 2012 | 09:31 PM
  #22
15 gallons. newer ones have 16, i think 98 up.
Old May 11, 2012 | 11:00 PM
  #23
mab6680's Avatar
i have a 97 z i always fill up on fridays with the gauge just above 3/4 of a tank and it takes about 11 gal a few times i have gone almost to E and it took just under 16 gal when full i can go back and forth to work all week wich is about 15 miles each way but as soon as that gauge goes below the 3/4 mark that gauge drops real fast
Old May 12, 2012 | 04:48 AM
  #24
llll1lll1's Avatar
Wow, only 15. I was really close to empty. I'm thinking fuel cell!
Old May 12, 2012 | 10:01 PM
  #25
2Z's's Avatar
So what exactly is the fix? Is it the float or the gauge itself?
Old May 12, 2012 | 10:43 PM
  #26
neither, its the shape and angle of the tank, its wider at the top and is almost on end so as the level goes down it goes down faster.
Old May 12, 2012 | 11:09 PM
  #27
2Z's's Avatar
Ahh, so no fix? I havent picked my car up yet, but the seller says he runs out between a 1/2 and 1/4 tank???
Old May 12, 2012 | 11:20 PM
  #28
running out above 1/4 i would suspect the pickup or the float is not working correctly. could be a bent float arm from a previous pump install. if the bottom of the pickup canister gets plugged i would think it would run out with quite a bit of fuel still in the tank.
Old May 16, 2012 | 07:09 PM
  #29
bob97z28's Avatar
I think mine may have a dif fuel tank, mine did 17.5 when it was close to empty. That wasnt with the pump locked either, i always hold it the whole time. I just looked at how much was in there and was like "wtf?" I didnt spill out, leak nor stopped filling at any point....
Old May 16, 2012 | 09:58 PM
  #30
99-02 tank is 16.9 93-98 is 15.5 i would say you were very very close to running out or you have a aftermark tank of some sort. or the station is ripping people off. wouldnt be the first time.
