LT1/LT4 Tech 1993-1997
What is the way to seal the water pump?
Old Feb 15, 2010 | 05:11 PM
Mr_Exacto's Avatar
Default What is the way to seal the water pump?
On a '94 Z28, what is the best way to seal the water pump when putting it on? Should I use a gasket maker by itself, new gaskets by themselves, new gaskets combined with a sealer, etc.?
I am replacing my Opti and decided to replace the water pump too.
Old Feb 15, 2010 | 05:14 PM
CraZ28's Avatar
Banned
Well I make sure to scrape and clean gasket surfaces with acetone and use liquid teflon on the bolts that go into the water passages.
Old Feb 15, 2010 | 05:50 PM
lt4weeda's Avatar
I just used the gaskets with a little bit of rtv on each side 10 thousand and no leaks
Old Feb 15, 2010 | 07:20 PM
i usually put a little high temp rvt on one side. then if removing, the gasket stays with one part.
Old Feb 15, 2010 | 11:03 PM
Mr_Exacto's Avatar
Thanks for the responses.
Old Feb 15, 2010 | 11:14 PM
Boosted8vfury's Avatar
I dont like my title
RTV ftw like the guys above said never had any bad luck with it knock on wood!
Old Feb 16, 2010 | 08:08 PM
torque_is_good's Avatar
none of the above, I just used the new gaskets
engin70
Apr 27, 2013 09:20 AM
rwing7486
Sep 16, 2012 07:48 PM
1998camarossclone
Aug 1, 2011 09:36 PM
ben50520012000
Apr 12, 2007 07:20 PM
