-   LT1/LT4 Tech (https://camaroforums.com/forum/lt1-lt4-tech-9/)
-   -   what heads should i do (https://camaroforums.com/forum/lt1-lt4-tech-9/what-heads-should-i-do-38038/)
93redz28 Apr 28, 2009 08:52 PM
should i do the lt4 heads with the lt4 hot cam kit???
or should i get something else???
what would be the best head and cam for my 93 lt1
i want it to be a streetable but street/strip!!!
what kind of chip?
pistons?
tranny? (MOTSY 4 SPD instead of my 6spd)
rear end?
pockets47 Apr 28, 2009 09:22 PM
Checkout www.Advancedinduction.com They got very streetable heads and cam packages at a very reasonable price. Depending on what power you want to make. Is the one that you will want to choose. If your going to do the pistons, I would just buy the whole Rotating assembley and get all done with. So you dont have to keep going back into the build. But again this is all about how much power you want and money you have to spend.
whammer3024 Apr 29, 2009 08:13 AM
you need to slow down...do some research before asking questions like this...i say this because you start asking about heads and then jump straight to pistons...swapping heads and swapping pistons are 2 totally different projects.
like pockets said...what are your goals? what are your current mods? what's your budget?
