What does it take to put a 94 z28 cluster in a 1993 z28
I think I found my problem with my speedo but it seems a never ending
Added problems to fix it
So I located a 94 cluster can't find 93's
From what I read the only difference is the tach signal/filter
If anybody has infor on this swap I'd appreciate it greatly
yep that little box by the coil thats taped to the wire harness. wonder if thats your problem. i remember reading something about it but cant find it. seems like the ecu needs a certain reading to use the rpm info, i just cant remember if it uses it after or before the filter. before i think. if thats the case all you should have to do is remove the filter.
93 pretty much doesnt interchange with any years. lol. unique freak. alot of the parts do interchange but alot dont. computer was made for 1 year in the camaro and 1 year in the 92 vette. only year 4th gen with the 4l60, does not have a maf, intake, exhaust, wiring, emissions, are different, only year with yellow lettering on interior *****. oh,,,lol, and they go faster.
