What does this go to?
Mine has a vac line running off of that port back to EGR valve. Look at the emissons sticker for the vac tube diaghram and it shows it (if you still have that label under the hood) Maybe you can save this image and zoom in on it enough to see the emissions label
duck hit her on the button, on mine that goes to the opti, but then mine is modified to a vented opti. shbox shows it as a egr vacuum source.
http://www.shbox.com/1/egr1.jpg
If it is a factory setup yes but if someone has modified your car, then it would depend on what they done. Like craby post, his is changed because of the vented opti.
