LT1/LT4 Tech 1993-1997
Question.....
Old 01-24-2008, 09:54 PM
Camaro_dudeZ28's Avatar
Default Question.....
I have a 1994 Z28 and I just wanted to know …. What is the largest radiator I could put in my car? If anyone can help me that would be awesome…
Old 01-25-2008, 02:14 AM
Spartan66's Avatar
Default RE: Question.....
why do you want a bigger radiator?
Old 01-25-2008, 12:46 PM
I was told that it could help with my over heating problem... I'm not too sure how much of that is true... but I do need a new one so might as well get a bigger one...
Old 01-25-2008, 02:05 PM
Spartan66's Avatar
before you go throwing a bigger radiator in there why dont you check your cooling system. My car ran VERY hot until i got my cooling system fixed and now it runs perfect. Whatare your cars symptoms? Overheating? Does it blow hot air or just cold? What color is yourcoolant in the radiator?
Old 01-27-2008, 02:36 AM
ss.slp.ls1's Avatar
Don't put in a bigger radiator, the oem one is sufficient. There are some things you could do. Check to see that your fans are working, check to see if your thermostat works, buy a pressure tester and look for leaks. My car used to lose water every day. Sometimes it would get low and my car would overheat. Turned out to be a few pin size holes in a couple of rubber hoses. Good luck.
Old 01-27-2008, 03:26 AM
Spartan66's Avatar
yeah mine was alot worse than that. The previous owner unplugged the cooling system and didnt plug it back so the water had no way to cool and so it cooked in my radiator and turned it coffee brown... plus the guy ran 50% distilled water 50% coolant.. which to me seemed odd.. like.. why not just fill it up all the way with coolant..
Old 01-27-2008, 08:08 AM
drumr2790's Avatar
Water cools better then coolant (antifreeze) usually. There are some coolants that do help vehicles run cooler though (for instance with bikes you sometimes have to get a special coolant that help the bike run cooler). Some people in climates that are always warm will just run 100% distilled and no antifreeze/coolant. I usually run a 50/50 mix. At a landscape job I used to work at we had premixed 50/50 for our trucks.
Old 01-27-2008, 12:12 PM
Spartan66's Avatar
its almost NEVER warm here lol.
JPrice
05-20-2012 03:48 PM
endo
09-30-2010 12:51 AM
josh75camaro
01-07-2010 09:09 PM
Quick Reply: Question.....
