LT1/LT4 Tech 1993-1997
What is this?
Old Jul 24, 2011 | 04:40 PM
NorthernCrew454's Avatar
Default What is this?
I found one of these on both sides after i took the oil pan gasket off, anyone have some info for me?
Old Jul 24, 2011 | 04:41 PM
BasicConcepts's Avatar
Technical User
it helps balance the bolt pressure for the oil pan
Old Jul 24, 2011 | 04:54 PM
does a new one come with a new gasket?
Old Jul 25, 2011 | 05:27 AM
mab6680's Avatar
no a new gasket does not come with them i cleaned mine up with a wire wheel and reused them
Old Jul 25, 2011 | 07:34 AM
those are supposed to go on the outside of the oil pan. between the bolts and the pan not between the gasket and the block.
Old Jul 25, 2011 | 08:41 AM
Apparently, a previous owner had the pan off, but obviously had no business doing so. As Basic said, those are reinforcement plates for the pan mounting flange. They go on the outside of the pan, and no, you don't need to buy new ones.
Old Jul 26, 2011 | 02:31 AM
rusty vango's Avatar
hilarious and i thought i had seen it all !!! were they between the gasket and block??
Old Jul 26, 2011 | 08:23 AM
Maybe the person who did that was reading some instructions that said the plates go below the oil pan, which is correct when the engine is in the car.
But the pan was installed while the engine was on a stand....upside down.
Old Jul 26, 2011 | 10:59 AM
torque_is_good's Avatar
how did it not leak?
Old Jul 26, 2011 | 01:24 PM
I was wondering that too. Lots of silly-cone maybe?
