LT1/LT4 Tech 1993-1997
A weld up dip stick hole?
Old 09-25-2011, 07:40 PM
numskull223's Avatar
Default A weld up dip stick hole?
Im fixen to change my oil because I cant check it. I had a valve cover leak so i figure its best to change it than run low.
For some reason the speed shop that built this engine seen fit to weld up the dipstick hole in the block for compressing reason, 12-1.......really? Ive never heard of that. My friend 2000hp twin turbo 427 mustang has a dip stick....lol. Was that nessary?
Old 09-25-2011, 09:30 PM
what the heck??? picture man,,,, id like to see this.
Old 09-25-2011, 09:40 PM
That is insane. I would never accept that for street use. What if you get a leak that only leaks hot and under pressure. You may not even see a spot in your drive way but in two weeks you have 500 lbs of scrap were your engine use to be.
Old 09-25-2011, 09:44 PM
lol, yah guy musta been thinkin, well its got a low oil level indicator so when the light comes on i add oil. or maybe couldnt get it to stop leaking. lol. yah i wanta see this.
Old 09-25-2011, 10:26 PM
yea, looks pretty clean actually, but dumb i thought. I have been scoping the under side of the car out everytime I park it.....lol scary.
Old 09-26-2011, 11:00 AM
mab6680's Avatar
why not change the dipstick tube not really hard
Old 09-26-2011, 11:16 AM
BasicConcepts's Avatar
Technical User
because the hole in the block is welded up... dont you read
Old 09-26-2011, 12:08 PM
mab6680's Avatar
yea sorry thought the top of the tube was welded guess im the numskull but can you spit my head out so i can put it back on
Old 09-26-2011, 01:27 PM
Technical User
sry that was my cousin hes an *** ive yelled at him about this
Old 09-27-2011, 12:43 AM
Ill take some pic this weekend of it. I wish it wasn't welded, tho...lol
Quick Reply: A weld up dip stick hole?
