LT1/LT4 Tech 1993-1997
Water Pump sensor
Old Oct 19, 2009 | 07:44 PM
jamesfs912's Avatar
Default Water Pump sensor
Quick question is the coolant sensor on the water pump called the Coolant temperature sensor or Coolant temperature sender? I just ordered the sensor just hoping it was not the sensor for the gauge but for the PCM. Thanks
Old Oct 20, 2009 | 12:22 PM
You picked the right one. GM calls it the Engine Coolant Temp (ECT) sensor. It talks directly to the PCM.
Old Oct 20, 2009 | 01:52 PM
jamesfs912's Avatar
Good ok thanks
sm515
Apr 27, 2014 01:27 PM
thebandit110
70-81 V8 Tech
Feb 27, 2013 12:43 AM
UFGatorFan
Feb 10, 2013 06:42 PM
gville4life
Feb 26, 2010 10:00 AM
r.serio
Nov 21, 2006 02:46 AM
