LT1/LT4 Tech 1993-1997
water pump drive seal
Old Jul 29, 2011 | 08:30 PM
1998camarossclone's Avatar
Default water pump drive seal
anybody know how to change a water pump drive seal on a 93 Z28. got a chandler motorsports cap and rotor and figured id better change the leaky one while i can. planning a long trip to ohio from memphis...anything i should be aware of?
used ebay opti
new chandler motorsports cap and rotor
vent mod
new fuel filter
new wires
new plugs
new oil
new air filter
any help would rule! thanks
Old Jul 29, 2011 | 08:51 PM
BasicConcepts's Avatar
Technical User
take the timing cover off and on the backside take a flathead place it on the edge of the seal and smack it with a hammer... while your at it get a whole timing cover gasket set comes with a new water pump opti and crank seal also a new timing cover gasket
Old Jul 29, 2011 | 11:07 PM
Don't take the timing cover off, if it isn't leaking. No need to fix what ain't broke, unless you like opening extra cans of worms. When I did mine, I didn't even mess with the crank hub or seal, as it was fine too. There's a trick to getting the new water pump seal on. To get the old seal out, there is a slot at the top of the opening where the seal fits into the cover, and you can pry it out with a screwdriver. Read here: https://camaroforums.com/forum/lt1-l...als-94z-43601/
Old Jul 30, 2011 | 11:56 PM
dude you are a legend
Old Jul 31, 2011 | 01:16 AM
Technical User
I'm a big fan of cans of worms
Old Jul 31, 2011 | 01:25 AM
Nooooo....really? You could probably eat fish for life with the worms you already have!
Old Jul 31, 2011 | 02:00 AM
Technical User
At least for a long time lol but seriously my car should be in driving condition in the next week or so
Old Jul 31, 2011 | 10:28 AM
im curious about this can of worms buisness...please do tell
Old Jul 31, 2011 | 12:20 PM
Technical User
i bought a 94 Z all it needed was an opti then i got it running and found it needed a trans so i decided to rebuild the motor i tore it all down gutted the interior sanded down the body basically took the whole car apart and all it needed was an opti big can of worms
Old Jul 31, 2011 | 03:24 PM
^ That doesn't sound so bad when you read it real fast! lol
