LT1/LT4 Tech 1993-1997
Valve Covers
Old 02-05-2008, 02:57 PM
95z281LE's Avatar
Default Valve Covers
I have a 95 Z28 and it is in the closing stages of being done. Today my builder set up the valvetrain and when he went to put the valve covers on they would not fit. He said its because of my rockers are hitting those tri-angle looking suports in the stock valve covers. Can I just cut those out or doI need new valve cover. If i do need new ones because i went with AFR heads theyare set up for either center bolt or standard SBC.
Old 02-05-2008, 04:50 PM
LT1RUNNER's Avatar
Default RE: Valve Covers
You can cut them out but you need to know exacly how to do it or you'll have problems with the rockers still hitting. You can go with raised valve covers to clear the rockers but then you're alternator will not fit. The alternator will hit on top of the valve covers. I took the easy way out and welded a small bracket to extend the alternator about an inch and I had to get a belt that was a little longer. It works out great and I've had no problems with it and I had it done at my work so it didn't cost me anything. I wish I had pics but I'm at work right now and the car is resting at home.
Old 02-05-2008, 10:02 PM
95slvrZ28's Avatar
You can cut one side of the support brackets and be fine. Somewhere I remember seeing the correct places to cut, maybe I can find it for you...
There you go! Courtesy of Golen Engine Services.
Old 02-06-2008, 09:10 AM
AV95Z's Avatar
I cut mine like that and have had no problems at all... just FYI
Old 02-06-2008, 02:32 PM
mxskater56's Avatar
I just bought tall valve covers for mine and got the fab shop I work at to knotch the valve covers so the alternator fit.
Old 02-06-2008, 11:23 PM
95z281LE's Avatar
We got them all cut up today and they fit like a glove. thanks for the helps guys.
Old 02-07-2008, 01:55 AM
95slvrZ28's Avatar
Glad it all worked out for you! Post up some numbers that the new motor puts down when you get it on a dyno or to the track!
Old 02-07-2008, 02:19 AM
Spartan66's Avatar
wait... you had someone else build it for you?
Old 02-07-2008, 02:32 AM
95z281LE's Avatar
Yeah I will try to get it onto the dyno ASAP but I have a 500 mile clutch break in first. And yes I had someone else build it.I love my car and I trust the guys I took it to alot more putting a motor together alot more then I trust my self.
Old 02-07-2008, 02:42 AM
Spartan66's Avatar
eh... imo that takes the fun and feeling of accomplishmentout of building a car... but to each his own.
Quick Reply: Valve Covers
