LT1/LT4 Tech 1993-1997
tuneing for turbo???
Old Aug 3, 2008 | 10:55 PM
ninety3chevyz's Avatar
Default tuneing for turbo???
i am currently in the middle of putting a t70 turbo in my 93z,i have upgraded the hole fuel system.i have put a 255 pump,bigger injectors,and a boost sensative regulator. but i am not sure what i am going to need as far as tuneing the car? does anybody know of a way to tune it for the turbo,or am i going to have to run a stand alone setup???if so,can anybody lead me in the right direction either way???
Old Aug 4, 2008 | 12:38 AM
95slvrZ28's Avatar
Default RE: tuneing for turbo???
You're going to have to find someone that is a good tuner that has a wideband O2 to measure A/F and a dyno. You're going to run into issues because you have a '93 which means you need to have a new MEMCAL chip programmed and installed, which is more specialty work than just reprogramming a PCM.
Old Aug 4, 2008 | 04:03 AM
no,i don't have the 93 setup anymore! i changed the comp. and wire harness to a 94 mass air setup!
96V6Camaro
Oct 11, 2021 09:41 PM
BM-Z28KING12
May 26, 2012 01:44 AM
