true duals
find a shop and get an estimate on getting a custom setup. See my posts in this thread:
https://camaroforums.com/forum/lt1-lt4-tech-9/new-exhaust-setup-opinions-59170/
texas speed has ls1 sets iirc, they may have LT1 kits as well. however they are NEVER easy with 4th gens. and typically cause a ton of problems. I personally wouldnt want to DD a true dual car unless a ton of work was put into the fabrication
Isn't the platform of an LS1 car the same as a 97-older? I would think you could then make an LS1 exhaust system work (if an LT1 isn't made) with some refabbing up front at the manifolds/headers.
Oh and craby, Gremany is right near Fracne and Ploand. You musta snoozed through geography class!
