transmission question
I have a 1995 Z28, 6speed. It seems that whenever i let out on the clutch it will jump and vibrate. the whole car starts to shake but once you get going it stops. it does it when you are downshifting too. i just bought the car, the guy said he just had a new clutch put in it. it doesnt seem that any of the motor mounts or transmission mounts are broken. i was wondering if anyone has had a problem like this, or know what it could be? thanks
I just put brand new flywheel, clutch and pressure plate on car. How do you get the clutch fork back on? After we put everything on, I got in the car and pressed in the clutch and it is too tight and the clutch wont push in at all. I took off the cylinder and the fork is pushed all the way in, and it's stuck.
