timing chain set
Going electric to "free up" some h.p. I presume? You do realize that an electric pump puts more load on the alternator, which in turn robs h.p.? Energy doesn't come free.
You can mathematically determine the horsepower cost at any given load. So lets do it exclusively for a 5 amp water pump
Amps x Volts = Watts
Watts / 745.7 (one HP) = Electrical HP Produced by the Alternator
HP x 15% Efficiency Loss = HP Loss
HP + HP Loss = Total HP Used
So this would be our EWP:
5A x 12V = 60 Watts
60 Watts / 745.7 = .080 HP
.080 HP x 15% = 0.12 HP
.080 + 0.12 = .2 HP Total
Anyone know much horsepower to run the driven pump? less than .2 HP??
5A x 12V = 60 Watts
So for an apples to apples comparison, how does the h.p. the motor in that electric water pump consumes compare to what it takes to spin a dry mechanical pump? Your pump's motor may be rated at a 5 amp draw, using .2 h.p., but what that formula doesn't tell you is what the added h.p. load of pumping the water would be. The pump motor can run on .2 h.p. dry, but not while pumping water.
