LT1/LT4 Tech 1993-1997
tightening vavle?
Old 01-15-2012, 09:15 AM
bob97z28's Avatar
i found a set of ls7 lifters for 125, good deal?
Old 01-15-2012, 09:20 AM
i would pull the valve cover and start the car to confirm its a lifter and not an exhaust leak. noise should get louder when you remove the valve cover.
Old 01-15-2012, 09:29 AM
bob97z28's Avatar
ok, is taking off the valve cover as easy as it seems? just those 1 or 2 nuts?
and just as simple to put back on?
Old 01-15-2012, 09:49 AM
BasicConcepts's Avatar
Technical User
its 4 10mm bolts but to get the left cover off you need to take of the alt
Old 01-15-2012, 10:27 AM
bob97z28's Avatar
its the driverside, but i guess ill go take a look,, i can start it with the cover off right?
Old 01-15-2012, 02:04 PM
Technical User
ya but some oil is going to get out its going to hit the exhaust and start burning
Old 01-15-2012, 02:16 PM
bob97z28's Avatar
how much oil, ive read that it can be alot, is that true?
Old 01-15-2012, 02:24 PM
Technical User
id say if you ran the car for 10 minutes you could lose about a qt but you only need to run if for 30 seconds
Old 01-15-2012, 06:12 PM
bob97z28's Avatar
ok,,, so if the noise gets louder that means i need a new lifter? do i just replace that one,,or do i have to do them all then? and is it a simple fix or would i have to make sure its a certain way? i couldnt find any info on it, (without cam or heads) and would ls7 lifters be fine?
  #20
Old 01-15-2012, 06:13 PM
bob97z28's Avatar
and is there a gasket on the valve cover i would need to replace or lube up?
Quick Reply: tightening vavle?
