LT1/LT4 Tech 1993-1997
Ticking from engine
Old Mar 30, 2013 | 07:22 PM
94ZSLP's Avatar
Default Ticking from engine
After being out of town for two weeks, I started my 94Z and was greeted with a fairly loud ticking noise from primarily the driver's side of the engine. The ticking did not go away after a 20 min trip.
Here is a short vid
I'm no mechanic, but that doesn't sound good. Could it be lifter..valves...help!
-Thanks
Old Mar 30, 2013 | 09:02 PM
wow i wish my engine was that quite,,,, not really. could not hear it, had both volume up all the way. could be a unhappy lifter or an exhaust leak.
Old Mar 31, 2013 | 01:42 AM
94ZSLP's Avatar
Yea. I just listened to the video, and my wonderful iPhone muffled the sound. It's really quite loud. If it is a lifter, how difficult is it to remedy? I live in a high-rise and must take my car to a shop for most work.
Old Mar 31, 2013 | 01:48 AM
what is the oil pressure at, at operating temp. at idle
Old Mar 31, 2013 | 02:14 AM
94ZSLP's Avatar
The aftermarket gauge barely shows any oil pressure at start up or warm idle - though since I didn't install the gauge, I have no idea how trustworthy it is. The same gauge showed 50-70 immediately after the last oil change - if that means anything. The engine runs very strong. Would sea foaming the engine help? It has 186,000 miles on it.
Old Mar 31, 2013 | 11:52 AM
what oil filter are you using? some fram filters will go to pieces and plug stuff up. also what oil are you using?
Old Mar 31, 2013 | 03:04 PM
94ZSLP's Avatar
I'm using 20w 50 synthetic oil and a Royal Purple oil filter.
Old Mar 31, 2013 | 04:07 PM
The sound stops momentarily at :17, then at :19-:22 I hear more than one lifter ticking. Better verify your oil pressure before driving it any further. If your gauge is right, you have a problem that driving will only make worse.
Old Mar 31, 2013 | 04:44 PM
yep with that oil you should have 20 to 40 lbs at a minimum. got something goin on. might try changin oil and filter and see what they look like. cut filter open and check for metal. that is thick oil for a lt1 it may be part of the problem.
Old Mar 31, 2013 | 05:34 PM
94ZSLP's Avatar
What oil and filter should I use? Should I run something through the engine to get the gunk of 185k miles out? If it is the lifters, is that an expensive job for a shop to do?
