Throttle Body Cleaning
While replacing my thermostat I noticed that the inside of the throttle body looks really dirty. Before the flaps its really clean, but past the two flaps it looks black and greasy, is it supposed to be like this?
no just bolt it back up and reconnect the throttle cable the idle will be the same also in mine wen i switched the plate on the bottom there was all gunked up coolant u might wanna check that as well
You don't need to take anything apart on the throttle body itself to clean it. Go to Auto Zone, or any parts store, and get a spray can of throttle body cleaner (not carb cleaner). With the engine running, spray the cleaner into the throttle body as you feather the throttle by hand. All the the built up varnish & gunk will dissolve and get burned up by the engine, leaving it shiny-new. If your TB is really gunky, you can spray it first with the engine off, scrub it with a toothbrush, then start the engine and spray it again.
No, I don't have it off, I just had the air intake tube off so I could see in the TB, but the only reason I was going to take it off was because I thought that junk couldn't get in the engine, but if you say it just burns away that's fine then, easier for me
