Tach signal
Trying to hook up a Moon tach and it's come down to two wires which are both black. My ECU is located in the trunk and I extended the tach wire with a black wire. I would like to identify the tach wire by the output when the car is running. What kind of a signal should I expect when the engine is idling?
this help so far this is all I have found
https://cimg4.ibsrv.net/gimg/camarof...a79a51577e.jpg |
Solved! Turns out the tach signal is a square wave which starts out at 12 volts and goes DOWN with RPM. I was probing it with the key on and thought it was gauge power.
When in a hurry and just cut wires, label them even if it's just A-A, B-B, C-C etc. Saves time.
| All times are GMT -5. The time now is 02:38 AM. |
