T-56 transmission?
T-56 transmission?
Hey guys, I have a 96 Z28, six-speed. Sometimes it won't let me put it into 2nd, I have to either put it back into first then back into 2nd, or put it in neutral, then to 2nd. Also, when i get on it and try to shift to 5th, it grinds???
RE: T-56 transmission?
I say you have some worn syncros. does the car or at least tranny seem to have a lot of vibration when you get on the pedal? Before I had my tranny rebuild, my syncros were all worn out and if I went full throttle my shifter would actually move up and down about an inch. I had a buddy who was bougth a car and it had a little grinding between gears and a little gear slippage he bought an additive for his tranny fluid, fixed his problem, you might want to try something like that.
Skip-shift was GM's way around the "Gas Guzzler" tax on the high performance 6-speed cars. It forces you to go from 1st to 4th and theoretically saves gas. Most people eliminate it because it's annoying. If that's the only problem you're having with your transmission you probably don't need to do any internal work.
dsinclair999
02-21-2011 11:24 AM
