LT1/LT4 Tech 1993-1997
supercharger, turbo or nitrous ???
Old Oct 27, 2009 | 06:35 AM
gizmop's Avatar
Cool supercharger, turbo or nitrous ???
I've got a 95 chevy camaro Z28 6 speed with a LT1 350 (new motor). I'm wanting to add more HP but, not wanting to spend that much money, around $3000.00. What should I do? If I go nitrous and headers what kind is best? Could I get a turbo for that price? If so what kind?
Old Oct 27, 2009 | 09:40 AM
torque_is_good's Avatar
May we assume that presently it's stock?
First, let's look at your $3k. What is "around $3k" ?
Next- are you prepared to do all of the work yourself?
If not, allow 1/2 for labor (it may be less but be safe)
so, the first thing you do is inhale and exhale better
CAI and LT headers followed by a Y pipe and then a catback. Whoops, you are already at around $800 - $1000 in parts depending on what you buy.
Now it takes in more air and exhales better. Take it for a ride and see if you like it.
You should also change the wires and plugs while doing this so another $100, again, assuming you are doing all of the labor.
Try that first and see if it satsifies your craving.
Old Oct 27, 2009 | 12:06 PM
Baldilocks01SS's Avatar
A Procharger for example is going to cost around $6,000 for the parts alone.
An STS rear mount turbo is a little cheaper at $3,000 for parts.
(None of the above include installation, but do come with beefier injectors, etc..)
Old Oct 27, 2009 | 12:46 PM
whammer3024's Avatar
ROTM Winner
yeah at this point i think supercharging it would be a bad idea...start with the basics and work your way up
Old Oct 27, 2009 | 06:20 PM
A Stinky Bumb's Avatar
you said its a new engine? well i would start by throwing N2O out the window! nitro on a stock engine is never good no matter what the car is! if its bone stock i would do what toqure said intake and full exhaust. then go a little electrical with wires and spark and stuff. then open her up and do some cam/injectors/rear end gears. after all that except the rear end gears then i would look at forced induction.
depending on how well the new engine is with compression you might want to replace seals and mabye higher pressure pistons so you can run the boost you obviously are hungry for!
summerized parts: (if bone stock) intake, headers, exhaust of your likeing, injectors/electrical, cam, then worry about high hp
Old Oct 27, 2009 | 06:39 PM
machine1999z28's Avatar
^^^+1
What is it with folks today? No one wants to start out with the basics and then work up. Come on people there's other ways to get power besides forced induction or nitrous.
Old Oct 27, 2009 | 07:17 PM
383Stro's Avatar
spray it with a 125 shot, stock everything... you can spray that much safely, without a tune, just make sure it is a wet shot. Take the rest of the money that you have left over and start where everyone else does.
Old Oct 27, 2009 | 10:30 PM
125 is not safe! he will use it over and over agian and that will wear down his seals like crazy! he will end up blowing his engine!
Old Oct 28, 2009 | 04:34 AM
cbr600rx7's Avatar
Your not going to be able to go boosted for 3K. Even a used kit will run around that and there are lots of added cost. Injectiors, Fuel pump, and other parts will add up. Plus you will need to have the car dyno tuned in to get the AFR and timing right.
If the car is stock or near stock headers and a nice little cam can wake up a LS1 and make her sound pretty damn sweet.
Old Oct 28, 2009 | 04:40 AM
maudyZ28's Avatar
do the work your self and its easy,
intake, cat back exhaust $600 minimum
headers from $250
cam $400
heads and valvetrain $1700
oh, were out of cash!! but some where around 400+ rwhp or good for 12s with stock gears in the rear
Sorry but in my oppinion n2o is not a good plan, who seriously wants to pay for a refil, and have to press a button to go faster, if its not under my foot in the go pedal its not worth having!
