stop the water
1 Attachment(s)
I had an idea a few months ago, finally got around to doing it. it was really simple really ; Install an 1/8 NPT street L in the weep hole of the LT1 water pump then a barb with hose to safely let the water flow under the car. here is the proof of concept
before picture |
1 Attachment(s)
first I drilled a hole about 3/4 inch deep
1 Attachment(s)
next was the tapping,
1 Attachment(s)
next was installing the street L, look how close the fitting is to the pump
1 Attachment(s)
almost finished
3 Attachment(s)
and it fits nicely
finally figured out how to put more than one picture up |
How do you keep the chips from the machining process from falling into the plump causing it to fail?
As a general rule machining an assembly that can not be taken apart and cleaned is a huge no no. One metal chip in the wrong place can destroy the assembly pretty quickly. |
Awesome idea dude.
So basically the purpose of doing that is to divert the coolant away from the opti should the water pump fail? Good safeguard I guess.
Originally Posted by Gorn
(Post 650523)
| All times are GMT -5. The time now is 09:27 AM. |
