-   LT1/LT4 Tech (https://camaroforums.com/forum/lt1-lt4-tech-9/)
-   -   Steering Column Question (https://camaroforums.com/forum/lt1-lt4-tech-9/steering-column-question-4141/)
ccdalamp May 21, 2006 10:29 AM
I have a 95 V6 Camaro with a manual transmission and I need to change out the steering column. Is there much of a diff between and automatic column and a manual shift. I have been told there are some wiring diffs. How much will that effect me?
Thanks
z28pete May 21, 2006 11:59 PM
RE: Steering Column Question
I really don't see why they should be different, but I never had to swap one. Why aru you changing the steering column?
shnormo May 22, 2006 01:18 AM
The ignition switch is different on the columns due to differnt neutral safety switches. Also the lock cylinders are different. On an automatic, you can just turn the key all the way back and remove it. On the manual steering column there is a button on the lock cylinder that must be depressed in order to bring the key back and for its removal.
