starter
Quick question, I have a mini starter and it drags when the engine is at running temp. I had the battery checked and its fine. So my.question is, can you rebuild it like ypu can a stock starter? And does that sound like a tired starter to yall?
sounds more like its over heating, try a heat shield first and see if that helps.
i use one on mine, its one of these Thermo-Tec 14150 - Thermo-Tec Starter Heat Shields - Overview - SummitRacing.com with this starter Powermaster 9502 - Powermaster XS Torque Starters - Overview - SummitRacing.com its been in for a year with no issues. first starter (tuff stuff) lasted 3 months without shield.
Originally Posted by craby
(Post 641504)
http://www.summitracing.com/parts/PWM-9600/ Thats not a sign thats somethings wrong with these LT engines is it? |
nope the motors not hot. try the shield first, its usually the windings that go south so rebuild will probly not do much.
(Post 641525)
It's not engine heat that's affecting the starter, it's exhaust heat.
Starter fine when cold, but not fine when hot...you have a heat issue. You want to try and isolate the starter from the heat source. |
(Post 641531)
| All times are GMT -5. The time now is 06:54 AM. |
