Special oil
I would think 5w30 like most over small block chevys.. It says in the owners manual. If you dont have one shoot me a PM and I can hook you up
As in my LT1 Vette, GM dropped the use of a separate oil cooler, and put in synthetic oil instead. I guess that says something about the stuff. Like I said though, I'm not positive they treated the Camaro the same way, but synthetic is still recommended. The Vette always got the better bells & whistles from the factory. Maybe for the Camaro it was only a recommendation, but not given to you when you bought the car new?
I'm sold on synthetic, and put it in everything (motor oil, gear lube, brake fluid). Regular oil is from the dinosaur age.
![Wink](https://camaroforums.com/forum/images/smilies/wink.gif)
that's all i use as well. now that i think about it, i'm pretty sure my stroker has 10w30 in it as well.
and i just went and looked at the SLP sticker from my car and it says "performance lubricants package" which i assume means all the fluids are synthetic. so its quite possible that a z28 did not get synthetic fluids.
