-   LT1/LT4 Tech (https://camaroforums.com/forum/lt1-lt4-tech-9/)
-   -   slave cylinder (https://camaroforums.com/forum/lt1-lt4-tech-9/slave-cylinder-52258/)
noz Jun 4, 2010 07:42 PM
slave cylinder
ok i looked everywhere and no body seems to answer this one i belive the piston on my slave cylinder came out how can i remove the line guys?
craby Jun 5, 2010 06:50 PM
what yr, model and trans?
noz Jun 6, 2010 12:42 AM
95 lt1 t-56, i have the whole assenbly out,i'll try to do the mod to adjust the clutch tomorrow
camaro_junky24 Jun 6, 2010 02:24 PM
there is a rolled spring in the 90deg brass fitting take a punch and push it out and put the new piston on its that easy and it is the same for all years with a t56 takes 20 min to swap
noz Jun 7, 2010 01:02 AM
i see what youre saying the spring tha pushen on the piston? so they do sell the kit with the seal to rebuild it right?
camaro_junky24 Jun 7, 2010 02:05 PM
wrong spring the one that im talking about is the one that holds the line on the cylinder with th piston that pushes the fork it looks lik a pin and autozone should have the piston assmbly in stock and there fairly cheap
noz Jun 8, 2010 01:30 AM
got you bro it engages smoth now..ready to get my black window on the street goin for the smog test tomorrow
