-   LT1/LT4 Tech (https://camaroforums.com/forum/lt1-lt4-tech-9/)
-   -   slap shift question on a4 (https://camaroforums.com/forum/lt1-lt4-tech-9/slap-shift-question-a4-61333/)
bobshannon22 Apr 27, 2011 06:53 AM
ok, so i got a 95 z28, a4. stock tranny if it matters, but the (ef me what it called) place where the drive, overdrive, neutral ,rev, and park are, but i have 2nd,d,od,n,rev,and park, no 1st gear option. I noticed today that if i hold it all the way back, like after 2nd gear, that i also have a first gear too. is this bad for my tranny because i dont have a 1st gear option?
im sorry it sounds so confusing, just wondering if its bad for the car cause ut might help me with hitting rev limiter on 1-2 shift
timmyz28 Apr 27, 2011 07:42 AM
No its not bad. I had the same exact thing. That means you have 2.73 final drive gear in the rear. All it is is a little rubber block under the middle console on the shifter. If you look at it, its a piece with the teeth in it to lock into each gear. I cut half of that block off so I had first as well. It won't do any harm, just don't do 60mph or so and slap it into 1st. It all comes down to common sense.
bobshannon22 Apr 27, 2011 10:45 AM
ohh,, nice, i might trip that block then, thank you,, 2.73, is that the good gears then? didnt they come with 2 dif packages?
craby Apr 27, 2011 10:52 AM
check your rpo codes, should be in the glovebox or center consol. sticker with a bunch of numbers and letters. rearend is a gu and then a number. like gu2 is 273 and gu5 is 323
timmyz28 Apr 27, 2011 12:08 PM
LT1s came with 2.73 for auto and 3.23 for 6sp. LS1s came with 3.23 for auto and 3.42 for 6sp. I'm not 100% about the LS1s though.
craby Apr 27, 2011 01:08 PM
nope, both my lt1 auto's had 323's
timmyz28 Apr 27, 2011 01:11 PM
Really? Dang man, I wish I was that lucky lol
