LT1/LT4 Tech 1993-1997
ruff idle with a surge.
Old Nov 15, 2014 | 09:18 PM
VALHAR's Avatar
Default ruff idle with a surge.
My new LT1 had a ruff idle with a surge. I found 2 problems. First, the passenger side breather hose had a crack on the under side at the throttle body where you could not see it. Replaced.
Second problem was with the pvc vacuum line where the rubber hose coming from the throttle body and connecting to the metal vacuum line was not connected.
fixed. Also I replaced the evap rubber hose at the throttle body because it was cracking. Idle very nice now. https://camaroforums.com/forum/membe...um-line-15719/
https://camaroforums.com/forum/membe...ure-map-15720/
VALHAR
Nov 3, 2014 12:23 AM
94z28chevy
Jun 19, 2014 10:04 PM
96LT1
Jul 8, 2010 08:51 AM
Z28maro
Nov 30, 2008 12:02 AM
BaByHuEy_05
May 17, 2008 04:55 PM
