LT1/LT4 Tech 1993-1997
Replaced Stereo, extra connector ???
Old 09-26-2009, 07:10 PM
remlle's Avatar
Default Replaced Stereo, extra connector ???
ok so I replace the stereo in the camaro today. I used a metra electric wiring harness and noticed it only had 4 channels. my Camaro came with 6 speakers, doors, back seats, and far back hatch area. the ones next to the back seats have stopped working. I was wondering if the extra connector went to those back seat speakers. if so does anyone know what the color code on them is? which one is left and which is right what is positive and which is negative?
Thanks in advance.
Old 09-26-2009, 07:16 PM
A Stinky Bumb's Avatar
i had this same problem i had an extra wire and my backs stopped working... try connecting that wire to an extra wire on the back of the unit. its like antanna power or something but it completes the circuit to the backs or something... try that
Old 09-26-2009, 07:30 PM
remlle's Avatar
its not an extra wire its an entire extra plug. I have the far back ones but not the "middle" ones the ones by the back seats. I hooked up the power antenna lead. Ive installed tons of stereos. never done a camaro. this connector has 9 wires I believe. one is bare almost like its a ground. after alot of google searches I think I found that it belongs to a CD changer option I dont have. the issue still remains that I have no middle speakers. Ive also read there could be an amp that needs powering but I dont know what wire it needs to power. Ive hooked up all the wires on the wire harness from metra.
Old 09-27-2009, 01:03 AM
greenarrow's Avatar
September 2009 ROTM
The stereo you put in the car is probably four channels if it's aftermarket. So in order to get those to work you would need to tap them into either the front or the back seat wires.
Old 09-27-2009, 07:48 AM
remlle's Avatar
ok but what wires are they? and where are they?
Old 09-27-2009, 11:38 AM
thats odd cause if you have the back one then the "middle" ones should be working too... wait do you have the bose system in your car?
cause if you do then you should have it all working if you have the far back "sub" working cause the back and the middles are all the same speakers and all run together..
Old 09-27-2009, 03:13 PM
remlle's Avatar
the head unit does not say bose and I dont have a subwoofer in the car. I have 6 speakers, 2 in the front doors, 2 in the rear by the back seats, 2 in the far back in the sails.
Old 09-27-2009, 03:27 PM
greenarrow's Avatar
September 2009 ROTM
Alright man, this is the only thing I could find and I don't know if it will help you or not.
Pin Wire Color Circuit Number Function
E1 Dark Green 117 Right Front input -
E2 Grey 118 Left Front input -
E3 Tan 201 Left Front input +
E4 Dark Blue 46 Right Rear input +
E5 Light Blue 115 Right Rear input -
E6 Yellow 116 Left Rear input -
E7 Brown 199 Left Rear input +
E8 Black 650 Ground
E9 Black 650 Ground
E10 Unused Unused Unused
E11 Orange 1040 Fused battery feed
E12 Orange 1040 Fused battery feed
E13 Black 1856 Left Subwoofer +
E14 Yellow 1956 Left Subwoofer -
E15 Dark Blue 1857 Left Front speaker +
E16 Light Blue 1957 Left Front speaker -
F1 Light Green 200 Right Front input +
F2 Light Green 1852 Right Subwoofer +
F3 Purple 1952 Right Subwoofer -
F4 Light Blue / Black 315 Right Subwoofer -
F5 Dark Green 1795 Right Subwoofer +
F6 Dark Green 1953 Right Front speaker -
F7 Orange 1853 Right Front speaker +
F8 Unused Unused Unused
F9 Unused Unused Unused
F10 Light Green / Black 1794 Left Subwoofer -
F11 Dark Blue / White 346 Left Subwoofer +
F12 Unused Unused Unused
F13 Red 1955 Right Rear speaker -
F14 Tan 1855 Right Rear speaker +
F15 Tan 1859 Left Rear speaker +
F16 White 1959 Left Rear speaker -
I know usually the wires are color coded, like one set will be grey, the neg side will have a black stripe. With this though, you should either have the subs or the rear speakers left over, look at the colors and see what you have left and then you should be able to figure it out.
Old 09-27-2009, 04:49 PM
remlle's Avatar
ok I found what appears to be an amp in the far back behind the spare tire on the passanger side. when I unplug it I lose all speakers. Im guessing its an amp.
Old 09-27-2009, 05:16 PM
remlle's Avatar
E8 Black 650 Ground
E9 Black 650 Ground
I tried to follow this and it looks like its 2 different plugs. not sure how to follow the above. here is the plug I have that has no connections on it. also found 1 wire going from car to the car harness that did not have a corisponding connection on the metra wireing harness. dont know what it does. its blue with a white line.
Attached Thumbnails Replaced Stereo, extra connector ???-imag0005.jpg   Replaced Stereo, extra connector ???-imag0003.jpg
Quick Reply: Replaced Stereo, extra connector ???
