removing oil filter mount
How do you remove the oil cooler from the block and where can i get the correct part to install to delete the oil cooler to run a oem filter?
i used a remote mount on mine. moroso 27382. i ran a hose from the radiator to the water pump to delete the coolant part of it and once you get the cooler out youll figure it out. should just be a matter of switching to another style filter. http://shbox.com/1/oil_cooler.jpg
i used this block off plate with a oil filter mount and ran hydraulic hose to it with 90s on the plate end. Moroso 23782 Oil Filter Block Off Plates
Here is the part that is left after you pull the cooler off,
Im looking for something that replaces this, so i can just spin a filter on in the same spot but without the cooler. i have seen them, but cant find them now??
yes. i dont remember if a different style filter is needed or not. i was going to go that way but it was pretty close to the headers. i do like my remote filter, i have it up by the air pump, makes changing easier and cleaner plus dont get oil on the headers.
