LT1/LT4 Tech 1993-1997
reg. maintenance
Old 07-31-2005 | 10:39 PM
deang423's Avatar
Default reg. maintenance
What is the best things to replace or check at 105,000 on a 96 Z.
thanks
Old 08-13-2005 | 10:36 PM
Default RE: reg. maintenance
grease tie rod ends, and lower ball joints
replace serpentine belt
replace engine coolant
check front wheel bearings for noise
replace transmission fluid and filter on automatics
replace spark plugs (this will teach u a lesson)
replace spark plug wires
change engine oil & filter
change fuel filter
change air cleaner
inspect brakes
inspect exhaust system
replace brake fluid
replace rear end fluid, use special additive for positraction
chck tires
align wheels
check for leaks
pmcculfor
06-07-2012 07:50 AM
Bobaloo
05-03-2012 12:19 PM
94Red
07-05-2007 12:12 AM
twelvenine2001V6
10-07-2006 07:48 PM
