LT1/LT4 Tech 1993-1997
rebuilt LT-1
Old Feb 11, 2009 | 07:13 PM
1bad93z's Avatar
Default rebuilt LT-1
hey guys i had a couple of questions i just had my LT-1 rebuilt and i put 373 gears in the rear and an LT-4 hot cam kit the piston are speed pro forged and eagle crank and rods new flywheel and timing chain new water pump and port and polished heads and intake and the question is how much power do u think the motor will have if i dont run nitrous and what would be my 1/4 mile times??
Old Feb 11, 2009 | 07:20 PM
95slvrZ28's Avatar
Ahh...punctuation...
From what I understood from that, you're only HP mods are the LT4 Hotcam and P&P heads. The HP you make is going to be mostly dependent on how well the heads were worked over. I would say you'll probably put down around 300-315 at the wheels, but it's hard to say. As far as the 1/4 mile, how well can you drive? The car is probably capable of a low 13, maybe even a high 12 if you have some good tires on it and the appropriate bolt-ons.
Old Feb 11, 2009 | 07:31 PM
1bad93z's Avatar
then i think its nitrous time then ladies and gentlemen
Old Feb 11, 2009 | 07:32 PM
1bad93z's Avatar
forgot one thing ive got long tube jet hot headers and texas speed and performance true dual dumps
Old Feb 11, 2009 | 08:46 PM
95slvrZ28's Avatar
Those were the "bolt-ons" that I was referring to...
Like I said, it's going to depend on how well the heads were worked over. The LT4 hotcam isn't a big cam, it's overall very mild for an aftermarket cam, so you're going to get a little power out of it, but not too much.
Old Feb 11, 2009 | 09:05 PM
Saint_Ali's Avatar
1bad93z....its not that bad
Old Feb 11, 2009 | 09:31 PM
1bad93z's Avatar
well with that bein said what nitrous system is good to go with, and should i put wet,dry,or a ''bag kit''
Old Feb 12, 2009 | 12:06 AM
Saint_Ali's Avatar
nitrous is a great way to destroy your engine
Old Feb 12, 2009 | 03:25 AM
Spartan66's Avatar
driving a car is a great way to destroy the engine.... nitrous just speeds up the process...
Old Feb 12, 2009 | 06:30 AM
Danko's Avatar
I had four SLP LT4s. Three were the Firehawk version (29 made) and one was the 30th Anniv. Camaro SS version (109 made). These were balanced and blueprinted with a lot of special susp goodies and ram air hoods and frankly ....... they were disappointing as far as 1/4 accel went. I do not have numbers but know they were nothing very special. I also had a Lingenfelter 383 Camaro and THAT ONE had the ACCEL!!!! They polished, ported, balanced and blueprinted and added headers and stroker kit and it dyno'd at about 450. Point being, adding some LT4 componenets might make sense if new parts are needed but to just plain replace parts just to use LT4 stuff is not enough difference to justify the bucks. Save your money and go visit John Lingenfelter's place instead?
