rear main seal
i need to replace the rear main seal, is it better to get a silicone or rubber seal ?
RE: rear main seal
Use the OEM seal, if there are no rough spots to tear into it, it should be good for at least 100K miles.
RE: rear main seal
i couldnt find an OEM, they jusy had some made by fel-pro, i also needed to get intake manifold gaskets,
will one of these fit correctly on a stock LT1 here |
RE: rear main seal
Fel-Pro is OEM (Original Equipment Manufature).
Fel-Pro is also a good choice for the intake manifold gasket set too. http://www.sellc.us/car/rearmain.jpg |
RE: rear main seal
ok thanks, im also looking at new valve cover gaskets, what is the best material for those ?
RE: rear main seal
Stick with Fel Pro. It's a blue silicone v/c gasket.
RE: rear main seal
i do plan on getting Fel Pro i just dont know what valve cover gaskets to get, there is rubber, rubber with cork, and rubber with metal
RE: rear main seal
Just stick with the plain old OEM style. They seal as good as any others.
