LT1/LT4 Tech 1993-1997
Rear end and suspention
Old Jul 12, 2010 | 09:14 PM
Lt1kidd's Avatar
Default Rear end and suspention help needed
I have a 97 z28 I'm looking to replace rear end and suspention I'm hopefull looking fir it to with stand 600-800 hp. I also want it to be street legal. Any suggestions.
Old Jul 13, 2010 | 02:37 PM
have a look at what spohns has.
http://www.spohn.net/
Old Jul 13, 2010 | 04:25 PM
whammer3024's Avatar
ROTM Winner
moser 12 bolt if you're planning on that kind of power.
you're going to want double adjustable everything
Old Jul 13, 2010 | 05:28 PM
Lt1kidd's Avatar
double adjustable everything as in what? Also will I need to reenforce frame?
Old Jul 14, 2010 | 02:22 PM
ROTM Winner
you will probably want 3 point subframe connectors
double adjustable is an option when buying suspension parts. with that kind of power, you're going to want the best of the best or you will blow up everything
Old Jul 14, 2010 | 07:42 PM
Lt1kidd's Avatar
Thanks whammer also what gear ratio will be best for street and track if feasable.
Old Jul 15, 2010 | 07:59 AM
ROTM Winner
are you auto or manual?
if auto, 3:73 gears. if manual, 4:10 gears
Old Jul 15, 2010 | 05:56 PM
Lt1kidd's Avatar
Thanks for all the help whammer one more thing what make fir the suspension would be best?Also what size axles will I need or will that be sized when I order the rear end?Another issue I will have is upgradeing the brakes. I really appreicate the help.
Old Jul 20, 2010 | 10:53 PM
ROTM Winner
spohn or UMI make great suspension pieces. sam strano has a lot of knowledge on what suspension pieces you need for what you're wanting to get out of your car.
as far as axles, i'd talk to whoever you get the rear-end from and tell them what you're planning to use it for. they will steer you in the right direction.
as far as brakes, a cheaper option for you is to go with an LS1 car's braking set up. its a lot better than our LT1 cars
Old Jul 31, 2010 | 03:33 AM
Lt1kidd's Avatar
Hey whammer slight change of plans think I trashed trans. It sounds like rubbing noise I got it up my friend said it was coming from the shifter boxo is that separate from the trans. If I need to replace the trans what do you recamend me going with??? Also where would I be able to get a service manual?? Wish I could contact you personally I think it would help better and how do I get a hold of the guy you recamended me about the suspension??
