LT1/LT4 Tech 1993-1997
Random Misfire
Old Aug 29, 2011 | 07:49 PM
  #21
Sheepdog's Avatar
I found a place in Georgia, Fuel Injector Connection, who will rebuild mine for 15$ each. Doesnt sound too bad.
Old Aug 31, 2011 | 01:20 AM
  #22
Sheepdog's Avatar
Garage tested it, said it was thew #7 cylynder, of course. I changed the plug and wire, only had a few hundred miles on the others, seems to be fine now. Seems like I dodged a bullet this time. Thanks fellas.
Hopefully, this was the only issue. I'll send the injectors in this winter after I park it.
This place rocks. I'll certainly be back. Maybe I can be of some help to others.
Old Sep 1, 2011 | 04:07 PM
  #23
Senshi09's Avatar
Originally Posted by Sheepdog
I can't afford 700$+ for injectors, thats if I put them in myself. Is there a rebuild kit for them?
before you go off spending hundreds of dollars on injectors, do what camaro69 said first. Find out which injector(s) are missing/clogged and soak them in carb cleaner. Cheap and effective. Saves hundreds of dollars on your end, only spending around maybe 3-5 for the carb cleaner..
Old Sep 1, 2011 | 09:06 PM
  #24
Sheepdog's Avatar
I'lll try that too, couldn't hurt.
auto
Jul 9, 2013 02:44 PM
ckaler05
May 17, 2010 05:45 PM
96ttopz28
Apr 11, 2010 11:37 PM
The Blackstallion
Sep 18, 2009 07:45 PM
hevymetalg
Feb 3, 2009 05:29 PM
