LT1/LT4 Tech 1993-1997
Radiator Swap (94 LT1)
Old 10-04-2009 | 10:06 AM
KawasakiJ14's Avatar
Default Radiator Swap (94 LT1)
My radiator has an unrepairable leak. Since it needs replacing, is it possible to remove the radiator without a lift? Will a jack/stands get the car high enough off the ground to make the job doable? If so, will I need to mess with the A/C condensor at all?
In a nut shell...is it worth doing this job or will it be a headache like almost everything else on these cars lol
Old 10-04-2009 | 06:43 PM
Mr_Exacto's Avatar
I replaced my radiator about two months ago in a '94 Camaro Z28 and I used jack stands. You do not need to remove the A/C condenser or unplug anything from it. Be careful about the low coolant sensor in the radiator because it can be tricky to put back on correctly. If you have any other questions, let me know.
J-Factor
09-24-2014 11:09 PM
bobarian91
01-13-2009 04:24 PM
birkenmeyer68
05-05-2008 07:37 PM
/M3
10-31-2006 01:04 AM
NillaGorilla
03-16-2006 05:43 PM
