quick question !?
quick question !?
heater is not getting well as warm as it should be getting in my brothers camaro! (94 z28)
the temp gets up normal temperature. but the heater never really gets warm .
and its cold please help me out thanks!
RE: quick question !?
Make sure you have the right t'stat, if you have a cold one the heater will also be cold. Otherwise the heater core may be partially clogged, or the air doors or controlsaren't working properly. Both hoses to the heater core should be equally warm and at the same temp as the radiator hoses. Cold heater hoses are an indication of a clogged core. Cabin temperature is controlled by air doors that adjust the amount of air going through the heater core.
There's another thread on here almost exactly like this not too far down the page about a '93 with the same issue. z28pete gave some good advice, I'd suggest you try those things first.
