LT1/LT4 Tech 1993-1997
Question
Old Feb 22, 2007 | 09:10 PM
Alabamian's Avatar
Default Question
How much would it cost to rebuild a LT1 engine from a local repair shop? and how many miles should you wait until you rebuild it? also how many miles would it last after you rebuild it?
Old Feb 22, 2007 | 09:21 PM
Default RE: Question
1)Cost, shop around your area & find out.
2)You rebuild an engine when it is worn out, usually turns into an oil burner, makes bad noises, etc.
3)A properly rebuild engine will last as long as a new engine. But it all depends how it is used and maintained.
Old Feb 22, 2007 | 09:26 PM
Alabamian's Avatar
do you know the average cost? i found a car i like but it has about 128,000. It has more miles than a average 96 model, but i need to know if i have the money it takes to rebuild incase something bad happens. Need it to last me through college and until i get a decent job.
Old Feb 22, 2007 | 09:46 PM
If the car runs good, has good oil pressure, does not smoke, and makes no funny noises, 128K miles is no big deal, and with good maintenance last to 200K. Rebuild costs vary widely across the country, but look beteween $1500-$3000, depending how much work has to be done to the engine, and how many new parts are needed.
Old Feb 22, 2007 | 09:52 PM
Alabamian's Avatar
alright thanks thats what i needed to know
JPrice
May 20, 2012 03:48 PM
endo
Sep 30, 2010 12:51 AM
josh75camaro
Jan 7, 2010 09:09 PM
