LT1/LT4 Tech 1993-1997
power window motor
Old Nov 3, 2010 | 02:08 PM
Jerry95lt1's Avatar
Default power window motor
my 95z has a problem with the right window. when i try to put the window up it does not have enough power and sometimes it doesnt go up at all. i have to do it manually. my question is if ineed the window regulator without the motor or with the motor. im not sure which one it is. how do i know if i need the window motor?
Old Nov 3, 2010 | 02:12 PM
you need a window motor, other than only working for a short time is there any other problem with the window? lose or rattle?
http://shbox.com/page/windowmotor.html
Old Nov 3, 2010 | 02:21 PM
Jerry95lt1's Avatar
no the window is fine. no rattles. i just have alot of trouble when im putting up the window. i usually have to start putting it up a long time before i get to my destination if not i have to get off and put it up manually.
Old Nov 3, 2010 | 02:31 PM
ricer_killaZ28's Avatar
I had the same problem, just got a new motor and used the guide craby posted and it works great now.
Old Nov 3, 2010 | 03:11 PM
yep you need a window motor. one thing you could do is replace the window stabilizer pads, they dont cost much and help to keep the window steady when half way down.
http://www.hawksthirdgenparts.com/br...r-Bracket.HTML
Old Nov 3, 2010 | 03:37 PM
sounds like i shoulda got those too. mine rattle when partially open
Old Nov 3, 2010 | 03:44 PM
Or....fix the poor factory wiring issue: http://autotrix.net/Product-Passenge...Fix-Kit_1.aspx
Old Nov 16, 2010 | 07:43 AM
W8NIC's Avatar
I had the same problem with my '95 z driver window, had to replace window motor..............
Old Nov 16, 2010 | 08:03 AM
evilkal's Avatar
You need the window motor. These cars are notorious for them to go out. They're cheap little units that aren't worth a damn.
Old Nov 17, 2010 | 04:13 PM
Jerry95lt1's Avatar
yeah i already bought a nw window motor. im about to install it during the weekend. thanks
