-   LT1/LT4 Tech (https://camaroforums.com/forum/lt1-lt4-tech-9/)
-   -   poor acceleration (https://camaroforums.com/forum/lt1-lt4-tech-9/poor-acceleration-36954/)
nlubrano Mar 30, 2009 02:35 PM
poor acceleration
i have a 1995 z28, Besides my bad rear end. could anything else be causeing poor accerlation. i have around 200 miles on both the trans and engine
rondavis Mar 30, 2009 03:18 PM
tps might be cruded up and not working right also what is done to the motor
95slvrZ28 Mar 30, 2009 03:36 PM
If you know the rear end is bad get it fixed and see if that clears up the problem. No need to stress and spend money on what might be causing the issue when you have a known issue that hasn't been repaired. There are many things that would cause "bad acceleration" but since you know the rear end is bad, get it fixed and see!
PAzYearazzUP Mar 30, 2009 04:47 PM
Brake drag/compression low/dirty air cleaner = Poor Acceleration
nlubrano Mar 30, 2009 07:44 PM
ok thanksss
Ridealldayz28 Mar 30, 2009 10:15 PM
your fuel is very important, you could have bad injectors, fuel filter, bad regulator mayby?
Ridealldayz28 Mar 30, 2009 10:32 PM
lt4weeda Apr 1, 2009 01:09 AM
after the fixing the read end. just stick to the 3 basics spark, fuel, and compression
