poor acceleration
If you know the rear end is bad get it fixed and see if that clears up the problem. No need to stress and spend money on what might be causing the issue when you have a known issue that hasn't been repaired. There are many things that would cause "bad acceleration" but since you know the rear end is bad, get it fixed and see!
