LT1/LT4 Tech 1993-1997
Plugs and Wires arcing issue
Old 05-28-2011, 05:13 AM
xXChipXx's Avatar
Default Plugs and Wires arcing issue
My car has been feeling like it is missing some, so I checked my wires for arcs in the dark. I could see that one is arcing constantly at the edge of the boot on the plug and another on the front of the engine that might also be on the plug.
Whats the best way to stop this?
Old 05-28-2011, 09:43 AM
greenmachine96's Avatar
New wires should fix it.
Old 05-28-2011, 09:46 AM
BTW Jegs makes red 8mm wires for 25 bucks plus shipping. Im satisfied with how they perform JEGS 8.0mm Red Hot Pow'r Wires - JEGS
Look through the list the lt1 wires are on there.
Old 05-28-2011, 09:52 AM
yep your wires are failing. time for a trip to the parts store. if i still drank i would rate the plug wire change at a 8 beer job on the beerometer.
Old 05-28-2011, 10:04 AM
Yar a strong willed matey then Craby. Working on an LT1 is enough to drive anybody to drink!
Old 05-28-2011, 03:02 PM
xXChipXx's Avatar
Well luckily my lt's will make it easier. I replaced my wires a few weeks ago when I did my lt install, but I only used regular wires. So using 8mm should fix it?
Old 05-28-2011, 09:12 PM
xXChipXx's Avatar
And is it significant that they are red wires. I've noticed everyone always makes a point to mention the color.
Old 05-28-2011, 10:14 PM
Grandpaswagon's Avatar
Color doesn't matter. You can get wires in different colors to match your engine bay, car color, or just plain artistic ideas.
But if you just replaced the wires, you should have any arcing unless:
1) You burned your wire or boot on the LTs.
2) You replaced them with some ultra cheap Chinese store brand wires?
Double check your wires for any signs that they have gotten burned on your headers. You may need to look for a new way to reroute them away from the tubes, or get some wire heat shields to protect them.
Old 05-29-2011, 03:23 AM
xXChipXx's Avatar
They are bosche brand, but im thinking that they are a bit too close to my headers. I have them routed in the way that I think keeps them farthest from the headers.
Old 05-30-2011, 07:32 PM
xXChipXx's Avatar
Will those wires resist heat better than 7 mm bosches from autozone?
Quick Reply: Plugs and Wires arcing issue
