LT1/LT4 Tech 1993-1997
p1361 code help
Old Dec 10, 2009 | 09:14 PM
ghostpopi's Avatar
Default p1361 code help
I have a 96 3800 v6 camaro with code
p1361 / ignition control circuit low voltage.
Can anyone tell me what exactly does this mean an what i need to do to correct it?
Old Dec 10, 2009 | 11:14 PM
Proper operation:
Both the camshaft position (CMP) sensor and crankshaft position (CKP) sensor signals are input directly to the ICM. The ICM sends 3X signals to the PCM, and controls the timing advance during engine cranking. The timing advance changes to PCM control after the following actions occur:
The PCM receives the second 3X signal
The PCM applies 5 volts to the ignition control (IC) timing signal circuit.
The DTC is set if the PCM does not see the 3X signal and does not assume timing control.
Check wiring and connectors between IC module and PCM. You will need a wiring diagram for your car.
Old Dec 16, 2009 | 03:33 PM
rba415's Avatar
i have the same code problem. where could i get a wiring diagram? i have a 95 camaro
Old Dec 16, 2009 | 07:23 PM
u could try a place like this
http://www.10xdownloads.com/your-fil...al%201996&cr=1
or pick a a factory service manual like this.
http://cgi.ebay.com/ebaymotors/1996-...e#ht_999wt_748
1998camarossclone
Aug 19, 2010 08:10 PM
jamez00
82-92 V8 Tech
Apr 4, 2008 10:26 AM
tycomps
Feb 16, 2008 09:56 PM
350rs
May 16, 2007 09:02 PM
dblock1989
Mar 6, 2007 08:54 AM
