LT1/LT4 Tech 1993-1997
Optispark Installation
Old Jun 19, 2012 | 06:25 PM
  #21
Ronk's Avatar
There's nothing in the cat, someone gutted it before I bought it. I didn't notice if it was glowing red so I'll take a look and see what happens.
Old Jun 19, 2012 | 06:33 PM
  #22
Don't bother, the cat isn't going to glow if it's empty, the catalyst is gone. That blows that test.
How about an exhaust sniff test, does your nose or your burning eyes tell you the engine is running rich?
Old Jun 19, 2012 | 06:44 PM
  #23
BasicConcepts's Avatar
Technical User
Originally Posted by Ronk
Not sure how I would check for fuel in the oil. Someone else suggested it's dumping too much fuel which I thought would account for the glowing exhaust? I've tested the fuel pressure several times, the last time just a few minutes ago and it's down to about 39psi with the key on, was about 40-42 a couple of days ago. I also pulled a vacuum on the pressure regulator and the fuel pressure dropped so it looks like a weak fuel pump at the very least.
pull the dipstick and smell the oil if it has a gas or exhausty smell theres gas in the oil
Old Jun 20, 2012 | 07:48 AM
  #24
torque_is_good's Avatar
ahhhhh, mystery vehicles because we have no clue what was done to them
ALDL OBD1 OBD cable OBDI OBD2 engine codes
buy the cable
LT1 PCM Tuning - Welcome!
use his service
the vehicle might have a modified fuel trim level programmed in it by a prior owner. There is nothing wrong with getting the computer flashed to a confidence level point and then see what issues are there
Personally, I'm a dog who refuses to chase his own tail
Old Jun 20, 2012 | 10:01 AM
  #25
it does sound like the opti is not right, how can it run fine then not and then find that the opti is 180 off. dont think it can run fine 180 off. im wondering if po upgraded to a newer vented opti that does not have the spined shaft or the timing gear does not have the needed spines and its slipped after a short time.
Old Jun 20, 2012 | 10:45 AM
  #26
Yeah, that deal with the 180 off didn't make sense to me either. An engine won't run with the timing off like that, no matter what type of distributor you have. The hub on the newer style opti won't fit through the older style timing chain cover, the hole is way too small. Something seems weird.
Old Jun 20, 2012 | 01:03 PM
  #27
yes, strange indeed
Old Jun 20, 2012 | 01:16 PM
  #28
Soitainly right. Eh, I mean try not to go off topic, yeah that's it!
Old Jun 20, 2012 | 03:32 PM
  #29
Ronk's Avatar
Yes, that's the general consensus from all who have sniffed the exhaust.
Old Jun 20, 2012 | 03:44 PM
  #30
You don't by chance have a picture of the back side of your opti, and front of your engine with the opti removed?
Something just seems weird.
