oil pump gear
hello all, i've had a problem with the drive gear for the oil pump. it been eating up twice now in the last year. do you guys think i have to replace the cam? its a 95 camaro z28 lt4 hot cam, headman headers, magna flow cat back, k&n air indution system, lt4 knock sensor, 1.6 rockers, behive springs, and a tune.
A real Lt4 cam from GM should be compatible with the stock pump gear. However you should be able to get sturdier after market gears from shops selling speed equipment.
a billet housing wont hurt ether.
check the wear on your cam and lifters to see if there centered.
1 Attachment(s)
im using a billet housing from herrin performance. they no longer have a website but you can get ahold of him on facebook.
Attachment 14765 |
yes i have to billet housing from herrin, when i get home i about 6 weeks or so im going to take it apart and see if the gear on the cam is ate up or not, i have a few parts to put on anyways so while im in there. thanks guys.
| All times are GMT -5. The time now is 09:22 AM. |
