OBD 2 fail
I have a 96 camaro LT1 and my obd2 wont connect with the obd2 scanners. ive been told that it could be a fuse or that the wiring is bad. i couldnt find a bad fuse, does a 96 camaro have an obd2 diagnostic fuse? im guessing it does not. what is the easiest way to solve the problem?
check your cig lighter fuse. from what i uderstand it supplies power to the diagnositc system. check all the fuses just for piece of mind. there are two fuse boxes one under the hood in a black box on the driver side fenderwell. the other is in the side of the dash on the driver side by the door hinge.
