LT1/LT4 Tech 1993-1997
No power steering
Old Sep 27, 2011 | 06:41 PM
timmyz28's Avatar
Default No power steering
So I put in a new pump and then did the air bleed procedure that shbox and my manual both have. They are also the same procedure I do at work so I know I'm doing it right. Well anyways, it doesn't whine or groan, no noises at all, no leaks at all, and fluid level is good. Everything checks out good except I have no power steering. What could it possibly be? Should I try flushing the whole system and redoing it or keep trying?
Old Sep 27, 2011 | 09:00 PM
timmyz28's Avatar
Never mind guys, I fixed it. The new (remanned) pump was bad. I took the hgih pressure side fitting off and found the check valve wasn't opening and it wasn't allowing fluid to pump completely through I guess. I put my old pump back on and now I have power steering again lol
Old Sep 27, 2011 | 11:55 PM
the dang reaman'd pumps suck. im on my third in two years and its goin.
Old Sep 28, 2011 | 01:48 AM
timmyz28's Avatar
Yeah man, I was a little ehh when I got this one. The parts guy at my job says they're discontinued through GM and you can only get aftermarket, and all aftermarket I called only had remanned pumps. Sucks
BasicConcepts
May 30, 2011 12:47 AM
shane1617
May 22, 2011 08:35 PM
Chasern1
May 11, 2010 07:31 PM
bohuntr
Oct 15, 2009 09:22 PM
my69cam327
Mar 8, 2008 11:14 PM
