No fuel reaching the engine
Hey guys I'm new to the forum and was hoping someone
could help me out.
I have a 1994 Camaro that I bought and that the last owner
had sitting for 4 years. It had an old alarm system hooked
up and I took that out I got a new battery and checked the
plugs and all is good except there is no gas getting to the
engine. I checked the fuse and its good I bought and
installed a new fuel pump but the signal from the engine is
not getting to the fuel pump. I'm guessing it may be the fuel
pump relay but the book says the relay is in the drivers side
and I cannot find it there. There is a box with relays in the
engine but none of them seems to be the fuel pump's can
anyone tell me exactly where I can find the relay?
could help me out.
RE: No fuel reaching the engine
Sounds like your theft deterent isn't enableing fuel. It gets that signal from the diode in the key. One thing that goes bad on those is the wires going from the key cylinder to the theft deterent module. I know cause my 94 Z28 had the same problem. Hope this helps.
