need more power
im looking for a way to add power. what else could i do for my car with a not too expensive budget? i have a cai, catbacks, shift kit, 75 shot of nitrous, an edelbrock throttlebody, and anything else on my signature i mightve missed.. thanks
For people on a budget like myself, i read an article and list in GM High Tech Performence magazine that will give you the best bang for the buck for an LT1 camaro.
-LT Pacesetter headers
-off road y pipe
-Hypertech Tuner
-LT4 Hot Cam Kit (with LT4 cam, 1.6 rockers, and valvesprings)
-LT4 Heads
-LT4 timing chain
-Granatelli High-flow mass air flow sensor
-SLP CAI
-2800 or better stall converter
-4.10 or 3.73 gears
-Magnaflow or Flowmaster exhaust system
-58mm throttle body
Believe it on not, with all of this stuff, it will put you in the mid to low12's or better according to GM High-Tech Performence magazine. I also read an article of some guy running 12.8 1/4 mile with only half of the stuff above installed into a 97 Z28. He did LT pacesetter headers, off-road y-pipe, magnaflow cat back, 52mm throttle body, 1.6 rocker arms, LT4 valvesprings, LT4 timing chain andcustom intake with k&n filter. So give that a go, looks like a good set up.
-off road y pipe
-Hypertech Tuner
-LT4 Heads
-LT4 timing chain
-SLP CAI
-4.10 or 3.73 gears
-58mm throttle body
Shorty headers will get you about the same power as LT's, but only if you get an aftermarket mandrel bent Y pipe. My suggestion is, if you're putting in all the work to get the old system off, and putting a new system on, you might as well get good quality LT headers and Y pipe and spend about the same amount of time under the car. Just my $0.02.
ORIGINAL: 95slvrZ28
Having shorty headers that bolt up to the stock Y pipe are useless. The Y is crazy restrictive, so the only way you'll ever get anything out of headers is if you replace the Y with a good one. As I already stated, I think shorties are a waste of time and money, again, there really is no difference in HP, but there is in low end torque, and yes, you'll be able to tell a difference. If I were you, I'd either get a good set of stainless headers or coated, that way you don't have to worry about them rusting out and having to replace them in the future.
I was told that with the long tube that there is an isue with rubbing espicaly when going over sped bumbs/humps and train tracks. Arizona speed and marine make a mid length header that is suposed to be prety good (looking inot them myself) and in place of the lt4 cams and heads you could go with a better set up and get the LE2 cams and heads thats just my opinion though. I belive it might cost more and you should get more bang for your buck though
