misfire help!
first off, car is a 1994 camaro z28, lt1, m6, about 150k.
when ever i fire it up, it misfires and runs rough until it warms up a little bit. even after its been warm and i turn it off and then back on, it does it again for only like a minute. i also notice that if I'm revving the engine up high when accelerating, it will do it when its around redline. optispark was replaced not too long ago, I'm thinking i just have a bad plug wire? any input is appreciated! |
When were the spark plugs last changed?
same time the optispark was, probably like 20 to 30k ago
sounds like a good time for plugs and wires. do you know what brand of opti was used?
i don't know what brand opti was used. ill try the plugs and wires, not looking to do an opti haha
Originally Posted by samkopyna
(Post 642864)
Originally Posted by torque_is_good
(Post 643060)
if you have stock exhaust manifolds I'd rather do the opti 3 times than try and replace plugs
its got headers on it, ill start with plugs and wires and see how it goes
(Post 643101)
21 Piece SAE/Metric Go-Thru Socket Set makes taking out #6 and #8 a breeze I was going to get the set at Sears for around $60 but saw this at HF a few months back and bought it. So far so good and it hasn't broken |
